Rocuk Posted October 24, 2020 Posted October 24, 2020 My bike is quite old and has recently been able to only run with the choke half way, not all the way up, the engine just pops to a silence when all the way up. Any diagnosis and ways to fix the problem would be greatly appreciated! Quote
dynax Posted October 25, 2020 Posted October 25, 2020 On my CG all the way up is the choke fully on, all the way down is the normal running position Quote
fastbob Posted October 25, 2020 Posted October 25, 2020 On my CG all the way up is the choke fully on, all the way down is the normal running position Correct . You wouldn't want the choke coming on when you go over a bump . Quote
fastbob Posted October 25, 2020 Posted October 25, 2020 So . If it runs on half choke but it doesn't run on full choke , clean or replace the air filter . It's got to have SOME air . It wouldn't be a bad idea to change the plug as well if the bike has been run on choke for any excessive length of time . Quote
