Hi all in need of abit of help just got bike back from garaged all fixed up just need to sort a new exaust out as mines looking abit flat🤦‍♂️, I've had the linkage measured where the pipe was cut and told its 60mm inlet size i need to fit exaust pipe.
I've been looking at exausts (Ideally delkevic or black widow) to fit an er5 and can't find any that'll fit. I messeged delkevic store on ebay and they said the exausts for an er5 is 51mm
Any help appreciated.
Cheers
I'm not sure I understand the question . All ER5's are the same so if there is a slip on can available then it will fit . Why wouldn't it ? Here's an example , have a read of the description in the link . Maybe you're confusing Slip- ons with cans that are options for aftermarket pipework . https://www.ebay.co.uk/itm/271555240369
