Stu Posted June 2, 2021 Posted June 2, 2021 When I installed this forum software I was advised to install it in a sub folder which I never was happy with! as a result the website URL became https://themotorbikeforum.co.uk/forum/ Note the "forum" at the end I have now moved the software to the root of the domain so there is no "forum" folder so now the URL is back to https://themotorbikeforum.co.uk If you have any saved links or bookmarks then please update these to reflect this for your convenience 5 Quote
husoi Posted June 6, 2021 Posted June 6, 2021 I don't like the new "unread" selection. Hides all unread before last visit. Quote
Stu Posted June 7, 2021 Author Posted June 7, 2021 7 hours ago, husoi said: I don't like the new "unread" selection. Hides all unread before last visit. I haven't changed it Quote
husoi Posted June 7, 2021 Posted June 7, 2021 1 minute ago, Stu said: I haven't changed it I'm not saying you have change it. Just saying that I don't like it. Very, very annoying. Quote
Stu Posted June 7, 2021 Author Posted June 7, 2021 49 minutes ago, husoi said: I'm not saying you have change it. Just saying that I don't like it. Very, very annoying. What exactly is your problem? As it works fine for me! Have you made a custom stream and made that on the default? Quote
husoi Posted June 7, 2021 Posted June 7, 2021 I used to just press the "Unread" button in the top menu to get all the unread replies. Now when I press it shows only unread messages since last visit. If I press is a second time after a few minutes it will hide everything. No, I haven't created any activity stream. Quote
Stu Posted June 7, 2021 Author Posted June 7, 2021 You have edited your default stream that's why. You need to find the correct stream and make it the default one or as you have done make a custom stream and make that default. 1 Quote
