Types of Motorcycle Licenses
There are three types of full motorcycle licences to aim for.
1. Category P - moped
2. Category A1 - light motorcycle licence - to receive this you must take and pass your test on a motorcycle with
* an engine size over 75cc but not more than 125cc
* a power output of not more than 11kW (14.6 bhp)
* a maximum speed of not more than 100 kph (62.5 mph)
You will now have full licence entitlement on any motorcycle up to 125cc and with a power output of up to 11kW (14.6 bhp). This licence is intended for riders of C90s and similar who don't intend to ride anything bigger. It will not become an unrestricted category A licence after two years.
If you take a test on a C90 or similar then you will have to take another test to ride anything bigger than a 125cc, 11kW bike with a maximum speed of over 100kph (62.5mph).
3. Category A - standard motorcycle licence - this is what you'll obtain if you pass your test on a motorcycle over 120cc but not over 125cc and is capable of more than 100 kph (62.5mph). With this licence you are entitled to ride a motorcycle up to 25kW (33 bhp) and a power to weight ratio not exceeding 0.16kw/kg. There is no restriction on engine size (cc) so you can now ride a bike bigger than a 125cc. There are plenty of bikes around in the 125cc to 400cc range that produce no more than 25kW (33bhp) You can ride a bike with a power output over 25kW but you'll need a restrictor kit on it to restrict the power output to 25kW. Any good motorcycle mechanic will fit a restrictor for you and give you the necessary documentation. Your insurance will cost more though because insurance companies tend to disregard restrictors. After two years you may ride any size and power of motorcycle without taking another test.
If you're 21 or over, or if you reach 21 within the 2 year period, there are quicker ways of obtaining entitlement to ride a more powerful bike. They are called the Direct Access Scheme (DAS) and the Accelerated Access Scheme (AAS).
If your practical test is passed on an automatic motorcycle the full licence gained will be restricted to automatic bikes only.
