Guest Posted July 8, 2023 Share Posted July 8, 2023 Hi all! I'm having some problems with my bike and would appreciate some advice. The issue: Bike strougles to start up without adding throttle, on cold and warm engine. Does not hold idle and it dies if throttle is not added. Bike rides rough, it looses power but sometimes it kicks back in until throttle realised. Checks/things that's been done: Fresh fuel in a fuel tank, breathing pipes and fuel line checked and in good condition, no cracks or blockage. Air box checked, cleaned, air filter clean, no blockage in air passage. Spark plug replaced and ignition coil connectors were cleaned and checked resistance on primary coil (0.30ohm) , spark plug cap cleaned. Spark visible and looks healthy. IAVS idle air sensor checked and it's functioning properly New injector unit mounted. New fuses all around All connectors checked Oil change Battery checked, charged Please let me know what else to check as I'm running out of ideas Quote Link to comment Share on other sites More sharing options...
