Interference Fit Posted July 16, 2023 Posted July 16, 2023 Worn once, gorgeous boots. https://www.ebay.co.uk/itm/195883500332?mkevt=1&mkpid=0&emsid=e12000.m113256.l116967&mkcid=7&ch=osgood&euid=dcd759657fb84f0a9dd53f530c41f434&bu=43112027729&osub=-1~1&crd=20230716081528&segname=12000&mkevt=1&mkpid=0&emsid=e12000.m113256.l116967&mkcid=7&ch=osgood&euid=dcd759657fb84f0a9dd53f530c41f434&bu=43112027729&osub=-1~1&crd=20230716081528&segname=12000 Quote
fullscreenaging Posted July 16, 2023 Posted July 16, 2023 You state they are too big. In what way? Are you struggling to change gear in them? If you’re struggling to change gear. Do you know you can adjust the gear lever? Quote
Interference Fit Posted July 16, 2023 Author Posted July 16, 2023 (edited) 1 hour ago, fullscreenaging said: You state they are too big. In what way? Are you struggling to change gear in them? If you’re struggling to change gear. Do you know you can adjust the gear lever? My foot is just a bit too loose in the boot to take up the slack with a thick pair of socks. Just doesn't feel secure enough, even with the laces tight and zip secured - I'm a very slim and tall build so my feet are quite thin and slender with no meat on the bone. I bought the next size down, but then my toe pressed against the end. They just not quite right for my foot size and shape which only became apparent after wearing them out doors in the real world. Edited July 16, 2023 by Interference Fit Quote
