Gentlemen,
I want to install LIGHTBAR with two 55W halogen bulbs. Here below, I attached simple diagram how I want to connect the lightbar.  The question is, is it OK to supply 12V to the bulbs from “POSITION LIGHT 10A ? Or, is it better to supply 12V directly from a battery (as shown in “green”) with extra 20A fuse. Please have a look. Cheers
Is this as well as the main head lamps or instead of?
if as well as, separate switch and fuse, also check the alternator is ok with the extra load.
if instead of I would check size of existing wiring. If you are replacing 1 head lamp with two. You are doubling the load.
Posted (edited)
remove the connection marked and its fine  other wise the ignition will be on all the time
Edited by fredc
add text
  • Like 2
