bateery problen help plz
i am trieing to charge mi bike battery and the charger has a dial with 1-7 on and its on one were do i clip to the battery itsself of the circle thing that conects to battery with two bolts and wies on it
actuall dnt no if i gt electric start it may be a cutout button how can u tell
Remove Batt
If Lead Constant Potential (Voltage)
If Ni-Cd Constant Current (Amps) charge
Batt will be either 12v or 6v depending
Red into + terminal
Black into - terminal
Time to charge a dead lead acid battery is 23 hours if cells have been under 7v for a prolonged time concider cells unusable and dispose of battery correctly.
Current in mAh (mA or A may be used) displayed on the battery shows the current charge 12v on lead should be around 1A no more than 2A i think!!! dont quote me on it.
WHEN CHARGING A BATT REMOVE IF FROM THE BIKE !!! FAILIAR TO DO SO CAN RESULT IN DAMAGE TO WIRING AND COMPONANTS ON THE BIKE.
STORE AND CHARGE IN A WELL VENTELATED DRY COOL PLACE WHILE CHARGING!!! FAILIAR TO DO SO COULD RESULT IN PERSONAL OR INJURY TO OTHERS.
RISK OF EXPLOSION, RISK OF CHEMICAL BURNS, RISK OF FIRE
I DO NOT TAKE RESPONSABLITLY TO DAMAGE TO PERSON(s) OR EQUIPMENT NOR PROPERTY IF APPLICABLE
sorry
power lock
two white clips female and male clips both say powerlock and four wires at botom were they go
all the details of yourr battery should be on the manufactors website with all the info you will need.
as for your question i dont know because your forum posts are hard to read and understand please try to use formal engish and try to spell check words your not sure about. my spelling is bad also so i normaly type up in MS Word 1st.
sean
ok well if you mean the ignition try a colour match 1st as its a switch it shouldnt matter as a switch isnt "poled" unlike a diod or LED switches, bulbs etc dont have a + or - effectivly
I believe he is being witty - I think he means a pull-rope type of starter, like lawnmowers and outboard motors.
