Marky1968 Posted November 8, 2024 Posted November 8, 2024 Hi all I want to change the oil and filter for a Bluroc Bullit 125 as I have just run in. Does it only take 1 litre of oil to change? Only I have found that on the web the service kit comes with just 1 litre of oil. I can’t see in the manual the correct amount of oil to use. Any help would be greatly appreciated Thankyou Marc Quote
Tiggie Posted November 8, 2024 Posted November 8, 2024 Managed to find it in the manual after a bit of searching. Not the easiest of manuals to read!! https://blurocmotorcycles.com/wp-content/uploads/2022/08/Bluroc_Spirit-125_Manual_EN-2021.pdf 1.3 litres is the amount you need for an oil change Quote
RideWithStyles Posted November 9, 2024 Posted November 9, 2024 Thanks tiggie! sometimes they say on the engine cases as the cast or a sticker. yeah so your just doing normal oil change so a litre is enough, if it had a completely stripped, cleaned and rebuilt engine it would need closer to 1.3. similar to Hondas 125c Quote
Marky1968 Posted November 9, 2024 Author Posted November 9, 2024 8 hours ago, Tiggie said: Managed to find it in the manual after a bit of searching. Not the easiest of manuals to read!! https://blurocmotorcycles.com/wp-content/uploads/2022/08/Bluroc_Spirit-125_Manual_EN-2021.pdf Thank you Tiggie for your help. Much appreciated. I totally missed this in the manual, as you say not the easiest to read 8 hours ago, Tiggie said: 1.3 litres is the amount you need for an oil change Quote
Capt Sisko Posted November 9, 2024 Posted November 9, 2024 (edited) According to this owners manual it's 1.7L ! - What does it say in the owners manual that came with the bike? https://blurocmotorcycles.com/wp-content/uploads/2022/08/Bluroc_Legend_125_Manual_EN-2021.pdf (their page 15, but my PDF reader say 22 of 33). Edited November 9, 2024 by Capt Sisko 1 Quote
JRH Posted November 9, 2024 Posted November 9, 2024 @Marky1968 put 1 let of oil in, check the level and add more till ok on the dip stick or viewing window. 1 Quote
Marky1968 Posted November 9, 2024 Author Posted November 9, 2024 9 hours ago, JRH said: @Marky1968 put 1 let of oil in, check the level and add more till ok on the dip stick or viewing window. Thank you JRH, I will need to buy another 1 litre then, not just a single litre Quote
JRH Posted November 10, 2024 Posted November 10, 2024 11 hours ago, Marky1968 said: Thank you JRH, I will need to buy another 1 litre then, not just a single litre The general consensus is it needs a bit more than 1 ltr. So yes get 2 litres and slowly top up til the correct level is reached. Quote
