Stick it in second as you enter the first part of the bend. By the time you have gone through both bends you should be at 50kph/32mph by the time you hit the speed trap
I know this is they way to do it on a 650, but does a 125 really get to 30 in 2nd? Not sure my old VanVan would have...
The distance from your starting point to the speed trap is quite short, and having two bends in it doesn't help. If it was a straight line then it would be fairly easy.
If you have a short gear ratio then you may hit 3rd gear, but Honda 125s are fairly well spaced so your not up and down the box in heavy traffic, so as you leave  the 2nd bend hit 2nd and open the throttle. You don't have the power to try a higher gear, it will just bog down so your basically going to have to give it some welly. Most school bikes end up knackered from hitting the rev limiter to reach acceptable speed
Second Billy’s post.
Use second gear, med revs around the corner (use the higher revs for stability and control) and about 3/4 around the long corner arc start increasing the speed towards the trap, it will still leave a few thou head room past the speed trap.
the low gear and higher revs it will help with braking when you need to stop at braking part. other wise it will bog and roll on, ull either have to change down or coast too much when you should be getting braking assistance from the engine as its in a low gear…
