Rockie Posted Tuesday at 19:04 Posted Tuesday at 19:04 So i have a suzuki intruder 125 2000, and i was riding perfectly find and pooof no lights, engine off. Ive come to realise that the fuse is blown in the starter relay, incoming end from battery. Even with ignition off, it will blow a fuse. uses 30 amp large fuse. Im completely stumped, gutted the whole wiring harness as much as i could out in the sticks and didnt find any issues. Anyone know what this could be? Quote
Simon Davey Posted Tuesday at 20:50 Posted Tuesday at 20:50 It could be the relay. Remove the relay, and see if it still blows fuses. Quote
_amw_ Posted Tuesday at 20:54 Posted Tuesday at 20:54 It depends on the specifics of the wiring. On a lot of bikes the 'starter relay fuse' (the 30 A one) is also the main fuse for the whole bike, so the feed going back to the fusebox is protected by the 'starter' fuse. If your bike is like that, the the problem **could** be that the feed to the fusebox is somehow shorting out (on the frame or another wire or whatever) and blowing the main fuse. Can you find a wiring diagram for the bike? Quote
RideWithStyles Posted Tuesday at 21:51 Posted Tuesday at 21:51 Id agree Definitely a short going on, as a general rule the starter motor and fuse is pretty much has the big/ main draw pretty much direct from the battery. Other than the starter, relay of something very close to it your leads to the cause is pretty short. Quote
Punts Posted Tuesday at 22:55 Posted Tuesday at 22:55 The 30A fuse feeds the regulator/rectifier with the r/w wire. Also the ignition switch and fuse box with the red wire. Unplug each one to see when it stops blowing the fuse, ( you can use smaller fuses to test as long as you don't turn the ignition on). Quote
Copycat73 Posted yesterday at 08:41 Posted yesterday at 08:41 burnt out winding on one of the phases of the alternator .. continuity test required on said alternator .. Quote
Punts Posted yesterday at 09:46 Posted yesterday at 09:46 1 hour ago, Copycat73 said: burnt out winding on one of the phases of the alternator .. continuity test required on said alternator .. If you disconnect the regulator/rectifier and it stops blowing fuses, it could be the alternator/stator Quote
