Bradleymarky Posted April 26 Posted April 26 Hi all. I have cat A on my license but not sure what it entitles me to drive and do I need any kind of training (I’m 56 if that helps) websites are quite confusing. Any help appreciated. Quote
Mold Posted April 26 Posted April 26 You can drive: motorbikes with a power output more than 35kW or a power to weight ratio more than 0.2kW/kg motor tricycles with a power output more than 15kW You can also drive motorbikes in categories A1 and A2. Quote
Mold Posted April 26 Posted April 26 DVLA says you can drive: motorbikes with a power output more than 35kW or a power to weight ratio more than 0.2kW/kg motor tricycles with a power output more than 15kW You can also ride motorbikes in categories A1 and A2. Category A1 You can drive light motorbikes with: an engine size up to 125cc a power output of up to 11kW a power to weight ratio not more than 0.1kW/kg This category also includes motor tricycles with power output up to 15kW. Category A2 You can drive motorbikes with a: power output up to 35kW power to weight ratio not more than 0.2kW/kg The motorbike must also not be derived from a vehicle of more than double its power. 1 Quote
bonio Posted April 26 Posted April 26 You need to look at column 12 as well. If it's like this with a number, then you have to check the number here https://www.gov.uk/driving-licence-codes If you score a 79, like the one above does, it means the category includes "tricycles" - i.e. three-wheelers only, and not "bicycles", i.e. motorbikes. Quote
Hairsy Posted Tuesday at 14:43 Posted Tuesday at 14:43 A little late to this one but I thought it might be sensible to add something in case someone uses the internet for their source of the truth (heaven help us!) This driving licence does not include motorbike entitlement other than Moped. Class A is motorcycles but, in the case, it is restricted to tricycles only (code 79.03). Quote
