techno Posted December 17, 2008 Author Posted December 17, 2008 Right put the thing back together ( so i dont loose anything) and now alarm dont work but its nothing obvious will get some jump leads and try that as thats pretty simple to do.As for anything else its way beyond me and it can sit in the damned garage till I can get someone to sort it.....!Thanks for the suggestions at least its winter.Oh and I had the same problem with the honda I had..infact upto this point its been the most reliable bike ive had Quote
slugworth1987 Posted December 18, 2008 Posted December 18, 2008 once your wired to a car's batt if still no joy the Kwaks HISS equivalent is suspect or the earth on the ignition key system... Quote
Guest Posted December 19, 2008 Posted December 19, 2008 Is it just the Start Circuit? I.e, does your Horn and lights work..What do you Ride?I had an issue with a bandit 600, aftyer riding in the wet, one of the sfatey circuits was at fault, so operate the side stand safety, and if it has one the clutch safety and the kill switch, then give it a go..If you don't have horn or lights working then its not the start circuit and is something else..PS if you can get at the starter relay and cross it with a screwdriver, and the bike starts then its in the wiring before the relay, Starter Fuse.. Quote
techno Posted December 19, 2008 Author Posted December 19, 2008 I noticed when I re-connected the battery the needles flicked accross the dials, no theres no lights or anything.Walney its a 2002 zx6r Quote
Guest Posted December 19, 2008 Posted December 19, 2008 I don't wan't to insult you, but the battery is connected the right way?otherwise i would check all your fuses, as it is interferring with all circuits, and not just the starter one, which could have been an immobilser.. If you have a haynes book of lies, then i would look at the wiring diagram for anything obvious... Have you had the bike apart or had work done porior to this probelm..? Quote
techno Posted December 19, 2008 Author Posted December 19, 2008 No I havent it worked i put it away then when i next got it out it didnt work.As i have no idea what I am looking at and have zero maintainance skills it will be heading for my usual garage in early feb.Thanks for all your suggestions! Quote
Guest Posted December 19, 2008 Posted December 19, 2008 http://www.kawasakimotorcycle.org/forum ... -help.html Quote
Guest Posted December 19, 2008 Posted December 19, 2008 If you try the Kwak Forum, theres a similar post on there, see above, he fixed it but closed the post rather than stated his findings.. maybe you can join and post him a message? Quote
Guest Posted December 19, 2008 Posted December 19, 2008 http://www.wiringdiagrams21.com/2004-ka ... g-diagram/This may help? Quote
Stu Posted December 19, 2008 Posted December 19, 2008 techno if i get chance i will pop across and take a look between now and feb save you going to the garage Quote
slugworth1987 Posted December 20, 2008 Posted December 20, 2008 i know you have visually inspected the fuse's but have you electricly checked them? using a multi meter set to the Diode/beep setting place the connectors acorss the terminals and if it beeps its good lol diode looks like this (|<-) as a symbol Quote
Guest Posted December 20, 2008 Posted December 20, 2008 i know you have visually inspected the fuse's but have you electricly checked them? using a multi meter set to the Diode/beep setting place the connectors acorss the terminals and if it beeps its good lol diode looks like this (|<-) as a symbolhis name might be Techno but hmmmmmmmmm nahhhhhhhhhhhhhhhhhh Quote
Guest Posted December 20, 2008 Posted December 20, 2008 where do you live mate? send me a pm if you dont want to put on here, see if i cant get over and bring a qualified mechanic and auto trition with me Quote
techno Posted December 31, 2008 Author Posted December 31, 2008 Just as an update...i am now more confused been out to bike all electrics now work but surely as its been stood so long wont start....will prob try to bump it off sometime soon and find it all dont work again Quote
Stu Posted December 31, 2008 Posted December 31, 2008 sounds like you have a loose connection usually the multi plugs behind the clocks and in the side of fairings are the culprit Quote
choppedminx Posted January 1, 2009 Posted January 1, 2009 sounds like you have a loose connection usually the multi plugs behind the clocks and in the side of fairings are the culprit I agree, I have found several 'not quite good enough' connections in the multiplugs under fairing. A good spray of WD40, and a few 'in and outs' (ooh err) with the plugs seem to fix it. Quote
techno Posted January 1, 2009 Author Posted January 1, 2009 Am thinking your probably right..gonna have another tinker when its warmer! Quote
Stu Posted January 1, 2009 Posted January 1, 2009 if you put the ignition on and just wobble wires and watch for the lights coming on and off thats the easiest way to check ps if it helps i have this problem on mine at the minute too but i know what wires it is Quote
