Guest Posted February 5, 2007 Posted February 5, 2007 Here's a list of things that are checked on the MOT, tick them off and you shouldnt have any problems getting a passMotorcycle MOT Test itemsa) Sitting on machine check: 1. All controls, switches and horn 2. Front suspension, forks, handlebars and head bearingsb) At the front of the machine check: 1. Front lights and indicators 2. Front brake master cylinder (if fitted)c) Place the machine on its stand and raise front wheel check: 1. Steering, front forks and head bearings 2. Front brake and wheel bearings 3. Wheel and tyre conditiond) Lower front wheel and go to right side of vehicle and check: 1. Frame, VIN, seat and foot rest 2. Exhaust system 3. Final drive (if fitted to RHS of machine) 4. Rear wheel, tyre and brakee) Raise the rear wheel and check: 1. Rear wheel, rear brake/components and tyre condition 2. Rear suspension and final drivef) At the rear check: 1. Rear position lamp(s)/stop lamp(s)/reflectors and indicators 2. Rear suspension 3. Registration Plateg) On the left of the machine check: 1. Frame and foot rest 2. Exhaust system 3. Final drive (if fitted to LHS of machine) 4. Rear wheel, tyre and brakeh) At the front of the machine check: 1. Wheel alignment 2. Headlamp aim 3. Brake performance Quote
Guest Posted September 17, 2009 Posted September 17, 2009 http://www.motuk.co.uk/manual/mc_contents.htm Quote
