its on Ω .. unless its set at the wrong setting.
i got:
2000k
200k
20k (one i used as was middle lmao)
2000
200
and screen shows the number 1 :P unless i am using completly the wrong meter lol
Josh
x
this is what im using
http://www.vlanshop.be/images_zoekers/652537_0.jpg
guessing this is the setting you want me on:
one lead on earth... one on lead... 0.6-0.8
same lead on earth... other lead on other connection... flashes numbers once(to fast to get it all) and then stays at 1.
Josh
x
This might help..
http://i250.photobucket.com/albums/gg250/simonevans73/ref44.jpg
http://i250.photobucket.com/albums/gg250/simonevans73/ref45.jpg
http://i250.photobucket.com/albums/gg250/simonevans73/ref46.jpg
http://i250.photobucket.com/albums/gg250/simonevans73/ref47.jpg
well that's telling you that you haven't got a fault to earth! :lol:
now you need to put a battery on and get bike going.
then put tester on battery on 30v dc scale and see what happens.
rwar we got there :D
need too get a battery (may ave to wait til next month)
and do i measure with the bike running? just checkin dont shoot me lol
THANKS rennie (and frankie :P)
Josh
x
yes get new battery and charge, check volts before fitting, should be around 12v.
fit to bike check again, should be same, start bike, check volts at tickover should be 12v-13v.
increase revs slightly, volts should go up a bit.
some bikes are high at tickover so just tell us what you get.
if all that's ok turn lights indicators brake lights etc on 1 at a time, all the time measuring volts,
volts should never go below 12v, if they do with back brake light for example then that's where fault is :lol:
ok?
let me know
ah! gotcha... ermm gtta get the bike tickin over first lmao! hopefully maybe jst a battery :P that will do it
will lets you know when i do :) thanks
one quick question.. the battery i got now has something like 4v in it .. dad says doesnt charge up (will let youknow when i actually try and charge lol) but how can the battery be dead if it has life in it? :/ lol
Josh
x
Josh
x
It will be dead if it cant hold a charge of 12v, the internals will be buggered, could be low electrolyte (distilled water.. which you can top up) but could be warped plates.. just because it holds 4v, its a third effective.. bit like your mobile when it holds charge for a matter of hours instead of days.. needs a new battery.. get it on an optimate and it will charge up or say its bust..
