uktriggersm50 Posted July 23, 2009 Share Posted July 23, 2009 please help i have a generic trigger sm 50 and need a wiring diagram as i am thinking about possibley fitting heated grips or a remote starter alarm not sure if i am but could do with knowing thanks Quote Link to comment Share on other sites More sharing options...
Guest Posted July 23, 2009 Share Posted July 23, 2009 please help i have a generic trigger sm 50 and need a wiring diagram as i am thinking about possibley fitting heated grips or a remote starter alarm not sure if i am but could do with knowing thanksHeated grips don't require a wiring diagram just the battery positive and negative connections..I wouldn't bother with an alarm or remote starter they're more hassle than they're worth... Quote Link to comment Share on other sites More sharing options...
uktriggersm50 Posted July 23, 2009 Author Share Posted July 23, 2009 what im wondering is how woullg they connect directly to the battery or through the wiring loop ? Quote Link to comment Share on other sites More sharing options...
Guest Posted July 23, 2009 Share Posted July 23, 2009 what im wondering is how woullg they connect directly to the battery or through the wiring loop ?Direct with ring connectors, and on most there's an on switch, which will turn itself off if the voltage drops, they can be fitted inline with the ignition/lights, but most just use the battery direct.. Quote Link to comment Share on other sites More sharing options...
