Guest Posted July 25, 2009 Share Posted July 25, 2009 Hi,It's my big day this Wednesday so I've got a few last minute questions which hopefully someone will be kind enough to help me out with!1) Should you be checking both shoulders everytime you pull away from a junction, roundabout or traffic lights? This seems to be the general consensus among the members here and I think most people would agree that there can never me enough checking. However, I was only taught the right shoulder check (for stationary occasions) in my CBT, and the useful videos published by Learn2Ride on YouTube also only advise this:http://www.youtube.com/user/learn2rideV ... 49qf5cAUrIWhat I guess I want to know is, will they definitely be looking for both in the module 2 test?2) It's obviously a necessity when moving, but when in stand-still traffic, should I always be leaving enough room behind a stationary vehicle so that they can see me? Even if it is a lorry which would probably require a good 10 metres or so?Thanks in advance guys Quote Link to comment Share on other sites More sharing options...
Stephen Posted July 25, 2009 Share Posted July 25, 2009 The way i was taught was that you check both sides when pulling away from a junction or traffic lights. But at roundabouts only a left shoulder check when entering the roundabout and another when exiting - checking the space you are going to be moving into. Whats happening on you right side isnt as important as thats not where you should be goingOh and question 2, I tend to stay more towards the centre of the road behind lorrys and slightly further back as it gives them chance to see me, not sure what you SHOULD be doing though Quote Link to comment Share on other sites More sharing options...
Guest Posted July 26, 2009 Share Posted July 26, 2009 The way i was taught was that you check both sides when pulling away from a junction or traffic lights. But at roundabouts only a left shoulder check when entering the roundabout and another when exiting - checking the space you are going to be moving into. Whats happening on you right side isnt as important as thats not where you should be goingOh and question 2, I tend to stay more towards the centre of the road behind lorrys and slightly further back as it gives them chance to see me, not sure what you SHOULD be doing thoughThank you Stephen, that's a huge help. If anyone else has any input on this it'd also be much appreciated Quote Link to comment Share on other sites More sharing options...
brooklyn Posted July 26, 2009 Share Posted July 26, 2009 Take a look at this. Its linked to RJH where you can get all the info you will need.http://www.motorcycle-training-forum.co ... -test.htmlhope it helps and good luck for wednesday Quote Link to comment Share on other sites More sharing options...
Guest Posted July 28, 2009 Share Posted July 28, 2009 Take a look at this. Its linked to RJH where you can get all the info you will need.http://www.motorcycle-training-forum.co ... -test.htmlhope it helps and good luck for wednesdayThank you - it certainly does help! Wish I'd have found it sooner.Can you, or anyone else, help answer another question that arose today? If a car is waiting to turn right into a side road and cannot due to oncoming traffic, is it acceptable in the test to 'undertake' between the kerb and the left hand side of the card? Obviously I'd only do this if there was enough room and visibility to do it safely - but would an examiner frown upon this? Quote Link to comment Share on other sites More sharing options...
YamahaWolf Posted July 28, 2009 Share Posted July 28, 2009 No, as long as you have enough room to pass on the left hand side it would be okay. Quote Link to comment Share on other sites More sharing options...
Guest Posted July 29, 2009 Share Posted July 29, 2009 No, as long as you have enough room to pass on the left hand side it would be okay.Thank you very much. One more question, if I may?When pulling over at the side of the road (as asked in the test), should I be using my left indicator and keeping it on until I move off again? Should I also be in neutral with both feet down?Thanks again guys Quote Link to comment Share on other sites More sharing options...
Guest Posted July 29, 2009 Share Posted July 29, 2009 No, as long as you have enough room to pass on the left hand side it would be okay.Thank you very much. One more question, if I may?When pulling over at the side of the road (as asked in the test), should I be using my left indicator and keeping it on until I move off again? Should I also be in neutral with both feet down?Thanks again guys No need now, asked the examiner and he said either way is fine. Oh, and I passed! Quote Link to comment Share on other sites More sharing options...
