Mk5Centurion Posted August 3, 2009 Share Posted August 3, 2009 Project ZZR has rumbled around to under the tank:Whilst checking over my pipe work i've discovered some that need replacing; one in particular needs doing - its one of 3 that join together at the back of the airbox (closest to front of bike) its 230mm (9 inches in old money) long, 5mm internal diameter and has a brass spigot thingy in it. Now the brass bit looks like its too big to come out and go into a new piece of pipe - is this a special part that i'll need to get (dealer perhaps?) or am i missing something with it? Bike is 1991 D model.Muchos gracias Quote Link to comment Share on other sites More sharing options...
Guest Posted August 3, 2009 Share Posted August 3, 2009 put it in boiling water to soften the rubber pipe, and it'll slide off.. if was a slacker fit, it would leak.. Quote Link to comment Share on other sites More sharing options...
Mk5Centurion Posted August 3, 2009 Author Share Posted August 3, 2009 put it in boiling water to soften the rubber pipe, and it'll slide off.. if was a slacker fit, it would leak.. Genius sir - i thank you! Quote Link to comment Share on other sites More sharing options...
