Guest Posted September 11, 2009 Share Posted September 11, 2009 anyone know if st helens test centre is a left or right circuit ? Quote Link to comment Share on other sites More sharing options...
Bogof Posted September 12, 2009 Share Posted September 12, 2009 anyone know if st helens test centre is a left or right circuit ? Both. The examiner chooses at the start of the test which way he intends to send you round the circuit. You cannot influence his choice and he will not (usually) tell you which he has chosen until he sends you off to the curve when it becomes fairly obvious. Although you may spot him walk over to the speed test equipment ahead of the test starting and switch it on, which gives you a pretty good idea Quote Link to comment Share on other sites More sharing options...
