Mk5Centurion Posted December 9, 2009 Share Posted December 9, 2009 I bought a new battery (Varta) for my old ZZR600 bus, charged up fine on the optimiser and sitting pretty with the "Charged and Maintaining" light on. Subsequently I unplugged it from the charger, and now that I've rebuilt the bikes carbs the battery is back on the charger - where its been for the last 2 days and it still only says "Charging" and not "Charged". Surely it should be charged by now? Quote Link to comment Share on other sites More sharing options...
Colin the Bear Posted December 9, 2009 Share Posted December 9, 2009 You got a multi meter? Quote Link to comment Share on other sites More sharing options...
Mk5Centurion Posted December 9, 2009 Author Share Posted December 9, 2009 Its not something i've got Colin - i can get a hold of one though.What should i be doing? Quote Link to comment Share on other sites More sharing options...
Colin the Bear Posted December 9, 2009 Share Posted December 9, 2009 Disconnect the battery charger and measure the voltage across the terminals. That should let you know what's happening with the battery. Make sure there's fluid in the battery. How long has the battery been stood? Never used an optimiser. Don't they put in differing amounts of charge depending on what the battery needs?As a last resort you could see what the instruction manual for it says? Quote Link to comment Share on other sites More sharing options...
Bogof Posted December 9, 2009 Share Posted December 9, 2009 for the last 2 days and it still only says "Charging" and not "Charged". Surely it should be charged by now? Disconnect charger from battery. Switch off charger. Leave for 5 mins. Reconnect battery to charger. Switch on charger.It's worth a try, as I have known chargers to get "locked" in one mode and a reset usually cures it. Quote Link to comment Share on other sites More sharing options...
Colin the Bear Posted December 9, 2009 Share Posted December 9, 2009 Oh no! Not the turn it off then turn it on again Quote Link to comment Share on other sites More sharing options...
Bogof Posted December 9, 2009 Share Posted December 9, 2009 Oh no! Not the turn it off then turn it on again It'll be even funnier if it works Quote Link to comment Share on other sites More sharing options...
Stu Posted December 10, 2009 Share Posted December 10, 2009 Oh no! Not the turn it off then turn it on again It'll be even funnier if it works it does work my optimate plays up every now and then and have to do this Quote Link to comment Share on other sites More sharing options...
Guest Posted December 10, 2009 Share Posted December 10, 2009 Oh no! Not the turn it off then turn it on again the amount of times just turning it off and on again fix's things Quote Link to comment Share on other sites More sharing options...
Pete Posted December 10, 2009 Share Posted December 10, 2009 Yeah I have that problem too! Whip the lead out and then stuff it back in her... Quote Link to comment Share on other sites More sharing options...
Chrissb6 Posted December 10, 2009 Share Posted December 10, 2009 Usefull link here with all the info you need for looking after your battery http://www.powerstream.com/SLA.htm Quote Link to comment Share on other sites More sharing options...
Guest Posted December 10, 2009 Share Posted December 10, 2009 Yeah I have that problem too! Whip the lead out and then stuff it back in her... Lead (pro' Led) or Lead (pro' leed) Quote Link to comment Share on other sites More sharing options...
Mk5Centurion Posted December 11, 2009 Author Share Posted December 11, 2009 Disconnect the battery charger and measure the voltage across the terminals. That should let you know what's happening with the battery. Make sure there's fluid in the battery. How long has the battery been stood? Never used an optimiser. Don't they put in differing amounts of charge depending on what the battery needs?As a last resort you could see what the instruction manual for it says? Measuring 12v across the terminals so it must be ok Quote Link to comment Share on other sites More sharing options...
Colin the Bear Posted December 11, 2009 Share Posted December 11, 2009 Stick it on and give it a go. Quote Link to comment Share on other sites More sharing options...
