Ok so the fairing on my FZS600 seems a little more wobbly the past few days.
I've checked all the screws but where the mirrors are attatched too with speed dial etc..seems to jerk (wobble) back and forth when going over any kind of small dip in the road.
It seems secure but is a tad annoying. Is it just because its got winder or have a missed a screw somewhere that needs tightening?
As stated its more the dashboard/mirrors that make the whole fairing move up and down (not left to right)
Cheers
Gareth
I don't know about fairing but clocks will move a little since they're mounted on rubber thingies. Like washers but much thicker...
Check to see if it has a front subframe holding it all on the bike it may have come loose
Look on the headstock between the forks :-)
The clocks move a bit but the whole fairing seems to bounce up and down and rattle (bit more than before)
Havnt fiddeled with anything but might of just gone over a bump and unlosened somthing will cehck tomorrow :)
Something has broken or come undone mate. Don't ride it until you find out why. If necessary, take it off and put it back on? :mrgreen:
What is described was exacly the problem. I thought the slight movement when riding it from start was meant ot be there but looking at the bike in the dry now i realised it seemed like the fram holding everything to the forks etc one of the bolts was very lose. Glad I noticed it and got it fixed. Nothing moves at all now not even a small shake.
Thanks Stu, and cheers to the rest of you.
even though its just tightening a bolt i feel quite accomplished :)
