cagiva mito evoloution 125 power problem
my bike bogs down and say if i stop and try start ot up its as though the battery has gone flat and asthough the batterys not getting charged.
hmmm.... it could just be a dudd battery. Maybe it's time to replace.
If the batterys relatively new, then I suggest you check your alternator next.
Get yourself a multimeter, only about £15? something like that.
Connect it up to your battery terminals whilst theyr'e still in the bike, it should read about 12 volts.
Now turn your engine on, the voltage should now read about 14 - 15 volts.
Flick your lights onto high beam etc. and check the multimeter again, might drop slightly but shouldnt drop much.
If you're getting really poor reading maybe it's time to replace your alternator
Welcome to the forum...... 8-)
Check the battery terminals are tight and not corroded.....may just be a loose connection.... :wink:
Welcome Andy. Also check the reg/rec, normally runs hot , but too hot and there's a dark brown smell. Check wires into it and make sure there,s a good bolted connection to metal.
