skikman Posted April 27, 2013 Share Posted April 27, 2013 putting a wee suzuki gs 125 together and cant get the lights to work properly.all lights work its only when i put the headlight on it cuts out the tail and side/dash lights.been switching wires around but cant figure it out.any ideas? Quote Link to comment Share on other sites More sharing options...
Tango Posted April 27, 2013 Share Posted April 27, 2013 Could be an earthing problem.....when it's pulling more current for the headlight......check all the grounding points for the headlight and tail lights..... Quote Link to comment Share on other sites More sharing options...
skikman Posted April 29, 2013 Author Share Posted April 29, 2013 ended up being corrosion at the switch.bit off a clean and wd40 and it works ok now.as always i had been through everything else and had everything apart before i got to the switch.why is it always the last thing you look at?anyway im just glad its sorted.thanks again folks. Quote Link to comment Share on other sites More sharing options...
klingelton Posted April 29, 2013 Share Posted April 29, 2013 ended up being corrosion at the switch.bit off a clean and wd40 and it works ok now.as always i had been through everything else and had everything apart before i got to the switch.why is it always the last thing you look at?anyway im just glad its sorted.thanks again folks. because if you found what the problem was, why would you carry on looking! Quote Link to comment Share on other sites More sharing options...
