aprilia having problems with gears?
Hi i was hoping someone here could help me,
I have an aprilia pro sport 93' 125, but when i'm riding it and change gear from 2nd to 3rd it feels like it's skipping 3rd and jumping to 4th the revs drop then when i click it up it goes into 3rd.. can anyone help me?
Difficult to say what's happening here....but it sounds like your selector forks in the gear box may be bent or damaged...... :shock:
I take it that the gear lever linkage is OK?.......don't know this bike, so I can't tell if it's got a fancy linkage or just a direct lever connection to the gearbox..... :)
thanks, it was the gears they was not set out the right way, even though i had the engine rebuilt at a garage, the bike runs perfect now.. but i need a clutch cable could you direct me to a site that i can check part numbers on so i know i am buying the right one, i have purchased 2 so far on ebay and neither of them fit..
