Dynamo_Delboy Posted June 14, 2013 Posted June 14, 2013 As the title says.en im starting my bike up and letting it warm up the battery gets drained within 5 mins.Its a new battery i pit in 2 weeks ago.Any ideas what could be causing it?The bikes a CBR600 f2 (1992) Quote
Stu Posted June 14, 2013 Posted June 14, 2013 Honda = more then likely dead rec/rec have you got a multi meter? check the voltage with the bike running Quote
Tango Posted June 14, 2013 Posted June 14, 2013 Not charging mate.......need to check the charging rate....but I suspect the Regulator/Rectifier could be shot......need to check the voltage at the battery with the bike off....and then with the engine running...... Quote
Tiggie Posted June 14, 2013 Posted June 14, 2013 he must be able to read 'the idiots guide' that little bit quicker Quote
Stu Posted June 14, 2013 Posted June 14, 2013 Talking of idiot guides fault-finding-diagram.pdf Quote
Dynamo_Delboy Posted June 14, 2013 Author Posted June 14, 2013 Think my bro in law has a multi meter.Ill get a loan of it an check the voltage whilst off and when the bikes running.Cheers guys Quote
buggerit Posted June 14, 2013 Posted June 14, 2013 as everyone else has said, i had that issue a few weeks ago, turned out the battery for me but when i tested it off the bike the optimate said good. the voltage was 12.3 if i remember but when i got a new battery it was around 13.5v fully charged. on the bike at around 5,000 revs think it hit around 14.9v or so. think really its going to be the reg/rec as your batterys new but you could check your wiring's ok after that alternator but im pretty sure reg/rec will sort it and their cheap and easy to fit. Quote
Dynamo_Delboy Posted June 14, 2013 Author Posted June 14, 2013 as everyone else has said, i had that issue a few weeks ago, turned out the battery for me but when i tested it off the bike the optimate said good. the voltage was 12.3 if i remember but when i got a new battery it was around 13.5v fully charged. on the bike at around 5,000 revs think it hit around 14.9v or so. think really its going to be the reg/rec as your batterys new but you could check your wiring's ok after that alternator but im pretty sure reg/rec will sort it and their cheap and easy to fit. Cheers mate Quote
Stu Posted June 15, 2013 Posted June 15, 2013 Did you download the pdf I posted above? Its full of info Quote
Dynamo_Delboy Posted June 15, 2013 Author Posted June 15, 2013 Did you download the pdf I posted above? Its full of info Im goona print it off today and go through it mate Quote
