just removed the top yoke to fit my new ignition barrel but cant get the barrel off the yoke two bolts they look like security ones anyone no how to remove them .They look dome headed can anyone help ..
if you can get a hacksaw or dremel to them, cut a slot and use a screwdriver
Yup buy the bits it's either that or drill them but chances are they have a pin in the centre which you will need to break off before you drill
In my experience they are designed in such a way you can't get a hack saw to them
