Guest Posted September 11, 2013 Share Posted September 11, 2013 I have a RD f1 which needs the fairing to be repaired is seen beater days had it from new I would wanted like new help please. ozzyrd Quote Link to comment Share on other sites More sharing options...
Tango Posted September 11, 2013 Share Posted September 11, 2013 Moved to Pistop.Welcome to TMBF mate......pop over to the Newbies section and introduce yourself to the nice people on here....... Please can you also put your location in your profile.......so that any advice given is relevant to where you are...... Quote Link to comment Share on other sites More sharing options...
Rik398 Posted September 11, 2013 Share Posted September 11, 2013 Welcome, Is the fairing plastic or fiber glass? If its plastic (abs) then you can repair faring with a piece of plastic gutter pipe (or any plastic really) and a heat gun. You basically burn plastic together with a soldering iron or something, stitch it, and then you can fill the gap with any other plastic you have lying around. I fixed my daytona fairing with a camping stove, a knife, and some old gutter pipe. There are a few vids on youtube which I used to help me and they are really good: This guy: "> and his general series is good. There is also another guy 'Dellboy's Garage' I think is the name, and he basically shows you that when you are doing a tab (where it bolts to the bike) or other part that takes stress, you can heat a paper clip and melt in into the plastic to give extra rigidity. It does work, and is not too tricky. If you don't feel up to it, then there are no doubt places you can send it to to get it fixed. The garage I took my bike to said they could have the fairing repaired for 60 quid, and that included paint so not such a bad deal. In the end I got a new fairing and fixed the old one up for a spare. If it is fibre glass, then you can get fiber glass repair kits and they will work just fine. Just don't use fiber glass kits on plastic, or try and use body filler. Will work in the short term, but over all you could have problems. Quote Link to comment Share on other sites More sharing options...
eastanglianbiker Posted September 12, 2013 Share Posted September 12, 2013 if you want it repairing and repainting back to original colours then these guys can do it for you http://www.dream-machine.co.uk/ Quote Link to comment Share on other sites More sharing options...
