Hi all bikers,
I would like to tease your knowledge and ask if anyone knows if i am able to change the garnish (fairings lol) by using another bikes fairings on my bike which is a 1994 Suzuki gsx600f, i heard that maybe a gsxr or similar, of the same cc (not necessarily year), could be a good match...any ideas including years, that would be suitable too? cheers all
I've been playing around with Kwak fairings - ZX6r on a ZXR750 and all is not plain sailing.
I've done a bit of offering up and it'll need brackets making and a good bit of adaptation. I'm just using what I've got but you might be a bit more lucky...
differences in frames/tanks/mountings mean its not likely you will be able to do a straight swap with anything, but with quite a bit of fabricating, it might just be possible.
:?: Why bother?
You can 'play' with your current fairings - a bit of cut and shape here and there, change the colour scheme, add/remove decals etc.
:cheers:
Does anyone know if any suitable aftermarket parts would work? Do they do such things? As for messing with my current fairings, never thought about it but its a possiblity.
any after market fairings will most likely be the same shape, just a different colour scheme. Most would be chinese and cost £££'s. Most pattern parts won't fit perfectly either, also some are known for paint peeling within a few weeks etc.
