cockercas Posted July 29, 2014 Posted July 29, 2014 Ok, so ive looked into other tracks as i had a awsome day at cadwell last week.But other tracks have lower noise limits then cadwell.Cadwell is 105db limit.I know someone who lives near mallory or whatever its called, but thats a 98db limit with ride by testing. Theres no way i can loose 7db and my bikes not the loudest by a long shot. How do others make the test limit? Quote
Tango Posted July 29, 2014 Posted July 29, 2014 You could fit a db killer for the track day and remove it after.... Quote
cockercas Posted July 29, 2014 Author Posted July 29, 2014 One of the baffles of ebay? Would they knock it down by 7db?Cadwell was ok, but according to the net other tracks noise test you before track time then moniter you as you ride. Would a baffle restrict prefomance? I suppose its just restricts the gasses exiting the engine so it isnt working as good as it could be, so that should mean power loss. Quote
littlecat Posted July 29, 2014 Posted July 29, 2014 it not necessarily the track itself that has the limit...different track day providers do different limits, and you'll often find weekdays and weekend limits are different Quote
cockercas Posted July 29, 2014 Author Posted July 29, 2014 it not necessarily the track itself that has the limit...different track day providers do different limits, and you'll often find weekdays and weekend limits are differentReally? I thorght it would of been set by the council. I looked at Mallory, it was 98db when I looked. Quote
Mr Fro Posted July 29, 2014 Posted July 29, 2014 Mine tipped 106 at Snet the other week and got told I needed to sort it or I might trip the track sensors.I went back 10 mins later, revved to 6k instead of 7k and got 99. Didn't get black flagged the whole day either. Quote
littlecat Posted July 29, 2014 Posted July 29, 2014 depends as I said... the 8th august at Mallory with no limits is 103db, whereas the Saturday one we have booked for the 30th is 98. ive also done donnington on a 'quiet day' , 98db with focussed events, whereas trackdays.co.uk have 2 days listed in august as 105db. Quote
littlecat Posted July 29, 2014 Posted July 29, 2014 as for the potential lack of power, tbh , at novice level it aint gonna make much difference Quote
cockercas Posted July 29, 2014 Author Posted July 29, 2014 I need the power, bigger bikes leave me on the straights then ride like children round corners. Any less power and I wouldn't be able to pass them in the corners Quote
littlecat Posted July 29, 2014 Posted July 29, 2014 that's bull... a 400 ridden decently will eat bigger bikes on the corners Quote
cockercas Posted July 29, 2014 Author Posted July 29, 2014 Yes, unless they pulled a big enough lead on the straights. Then your left playing catch up.That was the problem at cadwell. Out of barn, litre bikes would pass you on the straight, pass them between coppice and Charlie's then they would do you on park straight again. Quote
Stu Posted July 29, 2014 Posted July 29, 2014 Actually with a baffle in you will gain more mid range which will give you punch out the corners which will leave them struggling to catch up And as cat said a well ridden small bike will kill big bikes on the right track I saw a 125 and a zx10r battling at cadwell and the 125 won Quote
cockercas Posted July 29, 2014 Author Posted July 29, 2014 Il try a db killer then. I assume there the same db killers advertised on the bay? Quote
Stu Posted July 29, 2014 Posted July 29, 2014 I have a set of db killers off eBay and they do work They only cost a tenner each It depends what can you have too as to whether they will fit and you may have to drill a small hole Quote
golach808 Posted August 9, 2014 Posted August 9, 2014 that's bull... a 400 ridden decently will eat bigger bikes on the corners On sunday there was a 125 in the fast group at rockingham and he was going past all of the big bikes. There isn't much of a straight at rockingham (national) so the big bikes couldn't use there power to get past him Quote
cockercas Posted August 13, 2014 Author Posted August 13, 2014 Db killer knocked 7db off the bike. Was 105 without, now 98 with. Quote
The Hitcher Posted October 24, 2014 Posted October 24, 2014 I have a set of db killers off eBay and they do work They only cost a tenner each It depends what can you have too as to whether they will fit and you may have to drill a small hole Are these bike/pipe specific?, I've got an Akra slip on and I didn't get the baffle with it, would really rather not mess around putting the standard exhaust on, which I've heard it pretty close to the limit itself!!. Quote
Stu Posted October 24, 2014 Posted October 24, 2014 No they are universal I will see if I can find a link for ya Quote
cockercas Posted October 24, 2014 Author Posted October 24, 2014 I got a set of calipers and measured my exsaust, 50mm so I borght a 50mm db killer.Drilled a small hole and stuck a small bolt in. I wip it out after the noise test. Quote
cockercas Posted October 24, 2014 Author Posted October 24, 2014 http://www.ebay.co.uk/itm/DB-Killer-Baf ... 540b2194e2 Quote
Stu Posted October 24, 2014 Posted October 24, 2014 I cant find the one that I bought!! but to be honest there is loads on ebay Quote
The Hitcher Posted October 25, 2014 Posted October 25, 2014 Thanks guys, I will get one ordered up, the only thing is Akrapovics have that slightly funny exhaust shape but I'm sure there are db killers to suit them as they're a pretty common exhaust. Quote
