loose wheel? place near me charges me 5 quid to remove an old tyre and put on a new one, he supplies the valve. So I'd expect around that figure.
I had to get a front wheel looked at when I had a suspected puncture. Turned out I needed a new valve. All in cost £20 - wheel off, tyre off, new valve and all put back on again.
Well, wasted money in the end. After changing the valve and still losing pressure, I decided to resoke the tyre with soapy water and discovered the tiniest hole that I had missed last time I was looking. Plugged it with my cheap kit (which by the way has saved me a fortune over the last year and I would highly recommend buying one if you haven't got one already).
Oil and filter change today, just need to sort out the coolant sensor now.
