skiffer Posted January 23, 2015 Share Posted January 23, 2015 So.. The bike fell over in a bush. Initially I thought I'd been lucky cos it was a bush!! However I have now noticed a leak from somewhere around the oil cooler. I know this because the line looks like it's been dipped in crude. If it turns out to be the cooler then GREAT cos that's only 70 quid. However, these lines cost more than the actual rad!! Any suggestions of a place to get cheaper lines for the cooler if it comes to that? Gsf 600 98. Quote Link to comment Share on other sites More sharing options...
Stu Posted January 23, 2015 Share Posted January 23, 2015 the coolers are known for cracking Quote Link to comment Share on other sites More sharing options...
skiffer Posted January 23, 2015 Author Share Posted January 23, 2015 Yeah I've read that also.. A lot in fact. But I only noticed after it fell sideways in a bush. There was nothing for the rad to hit. So I'm forecasting worst case just incase. Quote Link to comment Share on other sites More sharing options...
Stu Posted January 23, 2015 Share Posted January 23, 2015 I have never seen lines split you may get the odd leak from the crush washers so you could try replacing these first but be prepared as when nipping it up it could reveal a crack in the cooler like my brothers did so if you use the bike daily look for other transport as a back up just in case Quote Link to comment Share on other sites More sharing options...
skiffer Posted January 23, 2015 Author Share Posted January 23, 2015 I've been using the alternative transport since I spotted it... my feet are getting unwanted mileage. Washers/o rings? Are on order. Read somewhere to strip it off clean it up dust it with talc and put it back on to find the culprit. You think? Quote Link to comment Share on other sites More sharing options...
Stu Posted January 23, 2015 Share Posted January 23, 2015 yup your heading down the right route Quote Link to comment Share on other sites More sharing options...
