jep Posted February 14, 2015 Posted February 14, 2015 cleaned my bike today but when it came to the back wheel rim I just gave up must have got some grease from the chain when I lubricated it a couple of weeks ago, can anyone recommend a good degreaser? cheers barry Quote
Throttled Posted February 15, 2015 Posted February 15, 2015 2 x WD40. Or Gunk that brushes on. The spray is disgusting as the fumes are horrible. Quote
igingeee Posted February 15, 2015 Posted February 15, 2015 I wanted similar advice after spilling chain cleaner/lube all over my rear wheel side-wall and rim.. I just wiped the excess of the side-wall with a towel and left the rim.Although it was advised in my case that warm soapy water should do the job, although I'm instantly guessing that it depends on how long the lube has been on the rim (as I noticed mine near enough straight after finishing the lubing process). Quote
