Front sprocket access.
Right, let's get this organised so I don't have any problems with this sprocket fitting on Sunday...
I'm comfortable with actually changing the thing, but... how am I getting the god damn gear selector rod out of the way? Went to clean the front sprocket last weekend and cover was all ready to be removed but couldn't fathom how to get the rod out. So far managed to take it off where it sits on the gear knob but can't get the cover off without more access from the rod...
Anyone with more experience going to tell me what's probably really easy to do and I'm just being rubbish...?
I'll get something up tomorrow. It's just the gear selector rod that is across the sprocket cover.
Previous experience is it can be a fiddly bugger to get the angle right but it will come off eventually
Ok here we go... As you can see, the sprocket cover is immovable unless I get the gear rod out of the way... which is a bit more tricky apparently than I would have thought... How does one take off that little bar steward!?
11041750_10155329254185305_8873724836981276623_n.jpg?oh=f174bb8fe654e0a1dfee9e7f3444b89a&oe=5582B14E
11043093_10155329254255305_2346820374078950134_n.jpg?oh=92b7adb10102ee6e16e21ed03d5a250f&oe=557D8003&__gda__=1434237166_190d4c682c4f4f32e08a5f71ef67173d
10922524_10155329254450305_8994323166285401793_n.jpg?oh=34087aefa38273681237ff37dc926003&oe=557E7B57&__gda__=1438181185_d3ee2dda37e4de1281eb3c9fbf8bbd53
11062773_10155329254290305_2513037787622393131_n.jpg?oh=eafc6c11fedb85fea9472d194ec641d5&oe=55808B21&__gda__=1435268212_1a6bf5d91c72ee969376c6412160e6b2
1512832_10155329254380305_7945021041818205360_n.jpg?oh=206c627b45e1ba099119e4647fdf6928&oe=557C293F&__gda__=1438462208_6177fb1198ac116dd807dae65b35a0e2
That pesky thing unscrews, it adjusts the lever height relative to the foot peg.
Referring to your last picture, undo the lock nut and unscrew the actual rod, this is how it worked on my old SV and RR which had similar shift rods.
Just when you put it back on make sure you like the lever position and move its position on the thread relative to that. Otherwise it might be too low or high!
looks like the ball joints will pop off if you get a lever behind them. cant see anything holding them on.
Thats a lock nut. so with the fiddly bit removed, slacken off the lock nut, then hold the shift linkage and unscrew the balljoint from the end of the shaft.
The shaft has flat spots on, so you should be able to get a spanner on there.
yep, and count the number of turns off, so that you can turn it back on the same number of turns!
also make sure you get the linkage back on the same splines.. so mark with a marker pen before you remove (if not too late!)
Ok good stuff, cheers mate. I'll get this all done on Sunday then!
Remove the foot peg hanger and slide it all back
That should give you enough access to get the sprocket cover off
Sounds like hassle! I'd do it the other way round - i.e. take the hanger off - only works if you can release the foot selector from the rest of the hanger though. Whatever works though. :-)
is it just the single bolt at the top holding it on?
with that removed, the cover might just slip down behind the shift linkage..
It won't - the cover is deep and the shift rod needs to come off. Actually just had a look at my service manual which corroborated this. Annoyingly, it doesn't tell you how to take off the shift rod.
11042678_10155329622185305_4179901516714244462_n.jpg?oh=074bddde64993cd062dc7dff46936a40&oe=557C22E9&__gda__=1433558020_3ae6a51fee68c6733c7c668b05f38b98
