Righto little bit of a rant, Had my float valves changed about a month ago. Mechanic said i'll need it back in 200 miles to check the flaot valves it's a 20min job. So i forgot about it went in today and he mentioned it would need to be with him a couple hours.. Now how legit is this? and is it something i could check myself? I jsut feel like he's mugging me off a bit ..
Cheers Stu, getting a bit fed up with this place, Never get back to me in regards to ordering parts and generally don't seem to give a rats ass, might try a different garage to check it.
to be honest with you I dont know why they want to check them again!
does it run ok now?
does it run ok now?
Unless they didn't set them right in the first place...
If it runs fine then no drama. :-)
but thats the thing why would he not set them right in the first place :?
not setting them right could have trouble right from the off :?
anyway I would look for another mechanic if your not happy
Seems fine tbh.. Only issue i had was earlier a splodge of oil dripped off after i'd been riding about 2 hours straight lots of start stop crap getitng through traffic (i mean tiny amount like 10ml at a guess)
Yeah think i might after the £400 bill last time i'm quite put off >.>
That's what I mean Stu. :-)
Where's the oil coming from? No excuse for having any leakage!
It appears (it hasn't happened since?) to be just above where the number 1 down pipe Will upload a photo later
Probably just need to nip up the valve cover a bit.
If they didn't fit a new one when it was serviced then you might want to replace it.
I assume that's the rubber black part on top? As far as i'm aware they're the old ones still. Noticed there is always some liquid seeping from them slightly.
Spark plug covers?
