Everything but the oil filter change went to plan.. oil filter is having none of it.. that's with the correct tool.
No leaks I can see. Though the exhaust at manifold sounds slightly different. That may be my ears though.
you sometimes have to butcher oil filters to get them off. stab them with a big screwdriver and wrench them round.
I was thinking exactly along those lines.... then I thought what if that doesn't go to plan. Doubt won that battle.
One of the downpipes isn't connected proper which is very annoying. You can hear it isn't sealed.
4 pipes at engine, one is blowing at manifold... I did it up in the wrong order instead of reversing the process. Gets hot instantly so made rectifying the problem painful. It'll wait til the morning. The noise is frustrating so it must be fixed.
downpipe isnt connected properly?? what at the engine end or the end where all 4 pipes meet up?
sounds like you could have dropped a gasket
I would get 4 new ones and replace them as they are cheap :)
If I don't fix this what happens??
It will be fixed Friday probs as the noise bugs me greatly. But I like to learn.
if you dont fix it
then it just bogs the hell out of you :lol:
sometimes the heat causes expansion and seals it up when hot
It drives me f ING mad.. even when going or opening up that little pathetic hiss is there in the back ground. I dried to create a seal this morning. Just waiting on new parts to arrive. Resisting urge to exhaust putty it. Just be messy doing it that way.
If my seals don't come it'll be the option I take for the weekend..
