MissBex Posted July 11, 2015 Share Posted July 11, 2015 Hey all, Just got an abba stand - want to try it out today but the fitting kit is confusing me - The bigger sized bit fits nicely in the hole and over the nut of fits both sides, the smaller bit (That looks the basically the same size as whats on the stand already) only fits over the nut on the right hand side of the bike, but it's not snug, it's more wobbly and loose - is that normal? Quote Link to comment Share on other sites More sharing options...
Tankbag Posted July 11, 2015 Share Posted July 11, 2015 On mine the solid bolt plugs for want of a proper description are different sizes to march the different sized holes, but they are definitely not wobbly ! Did ABBA send you the right fittings ? Quote Link to comment Share on other sites More sharing options...
MissBex Posted July 11, 2015 Author Share Posted July 11, 2015 They sent me Fitting Kit 2. I have no idea if thats the right one :/ the fittings for mine are the cup types. Quote Link to comment Share on other sites More sharing options...
Tankbag Posted July 11, 2015 Share Posted July 11, 2015 Is it the cups that feel wobbly ?When you tighten up the winder mine feels totally stable , test how wobbly the cups feel after you've tightened the winder handle Quote Link to comment Share on other sites More sharing options...
Tankbag Posted July 11, 2015 Share Posted July 11, 2015 Post some pics Quote Link to comment Share on other sites More sharing options...
MissBex Posted July 11, 2015 Author Share Posted July 11, 2015 Is it the cups that feel wobbly ?When you tighten up the winder mine feels totally stable , test how wobbly the cups feel after you've tightened the winder handle I will try that first then upload and link a short vid if not. ThanksEdit: Sorted! You were right, they are tight once I fitted the stand and tightened it Thanks! Quote Link to comment Share on other sites More sharing options...
