fq-craigus Posted November 25, 2015 Share Posted November 25, 2015 My dad has a yamaha trx 850, he has finally started gaining more intrest to ride it and has even mot'd it. Now he has made noise that he wants a better exhaust, something deeper rather than the standard whistly things. I have had a look online and can only really find either stock or delcovic silencers. He likes the sound of both akra and scorpion but we cannot find any for love nor money. None thats listed for the trx anyway. Does anyone know what other silencers will fit? He wants to keep it twin pipe. Also short term i have said about removing baffles but its not so straight forward so it seems. When you remove the fancy plate on the end of the exhaust your left with what looks like the baffle tube welded in place and in the bottom of the exhaust there is no fixings i can see that can be drilled out ect for the bottom of the tube. Any help would be apreciated http://images.tapatalk-cdn.com/15/11/25/6d69e3da7e62ab6a18daafa94a0409bb.jpghttp://images.tapatalk-cdn.com/15/11/25/eb92974a8dcc10fe8a20f8be421f832f.jpg Quote Link to comment Share on other sites More sharing options...
Adam Posted November 25, 2015 Share Posted November 25, 2015 Baffles are usually only fixed at one end so if you drill out the welds you should be able to remove them. If you google baffles you'll see what I mean. Quote Link to comment Share on other sites More sharing options...
fq-craigus Posted November 25, 2015 Author Share Posted November 25, 2015 Baffles are usually only fixed at one end so if you drill out the welds you should be able to remove them. If you google baffles you'll see what I mean. its a bit of a strange layout there is a raised bit which is seam welded. Ive removed baffles before but with it not being my bike i would rather know what im facing Quote Link to comment Share on other sites More sharing options...
eastanglianbiker Posted November 25, 2015 Share Posted November 25, 2015 beowulf do after market end cans for this bike but they are not cheap Quote Link to comment Share on other sites More sharing options...
Guest Posted November 25, 2015 Share Posted November 25, 2015 Craig, have a go at removing the baffles... if they are welded, it will just be a spot weld at one end. Paint them black job done!If he wants an akra sound, pop some perforated steel tubing inside with some exhaust packing. If you do F*** it up, surely stock cans are easy and cheap to come by... Quote Link to comment Share on other sites More sharing options...
Paul-Kent Posted November 25, 2015 Share Posted November 25, 2015 I had ART cans on my trx, sounded lovely with those on!http://i17.photobucket.com/albums/b58/pcritcher/bikes/null_zps31800109.jpg Quote Link to comment Share on other sites More sharing options...
fq-craigus Posted November 25, 2015 Author Share Posted November 25, 2015 Craig, have a go at removing the baffles... if they are welded, it will just be a spot weld at one end. Paint them black job done!If he wants an akra sound, pop some perforated steel tubing inside with some exhaust packing. If you do F*** it up, surely stock cans are easy and cheap to come by...he wont let me chop about unless all is clear and i got better things to spend £40 on lol Quote Link to comment Share on other sites More sharing options...
Tango Posted November 25, 2015 Share Posted November 25, 2015 How are the current cans attached to the link pipes? There may be some non bike specific ones that'll fit..... Quote Link to comment Share on other sites More sharing options...
fq-craigus Posted November 25, 2015 Author Share Posted November 25, 2015 How are the current cans attached to the link pipes? There may be some non bike specific ones that'll fit..... There is a angled pipe in the bottom of the silencers so the dont stick out if there was a straight fit i have found a few but unfortunatly not that easy Quote Link to comment Share on other sites More sharing options...
Tango Posted November 26, 2015 Share Posted November 26, 2015 You can get angled connecting pipes Craig.......They do them for the Bonneville to kick the cans up a bit.... http://www.ebay.co.uk/itm/131154150288? ... EBIDX%3AIT Quote Link to comment Share on other sites More sharing options...
