finally going to get round to pulling the Kawasaki Ar125 B1 out 1984, i will update you with some photo's soon.
This one is for road use For fully comp £156,18 ..... wow that's cheap time to get road legal.
http://i1156.photobucket.com/albums/p562/classickid21/Old%20Photos%20of%20motorcycles/1365972991380_zpsdietpydq.jpg
http://i1156.photobucket.com/albums/p562/classickid21/Old%20Photos%20of%20motorcycles/the%20ar_zpsmmikl0hb.jpg
picking up a donor this Monday possible weekend.
happy days!!
http://i1156.photobucket.com/albums/p562/classickid21/kawasaki%20ar125%2084%20b1%20build/9230952C-F01D-4766-AEB0-E1A403ADCF49_zpsfbbmcdug.jpg
Rear wheel polished and no longer black :) getting there slowly! Front wheel i have started but is a long way off being done.
Rear wheel looks awesome
http://i1156.photobucket.com/albums/p562/classickid21/kawasaki%20ar125%2084%20b1%20build/C98F6D57-C630-48A6-A542-A1637834CF78_zpscv0v2udm.jpg
front wheel will be Tuesday hopefully all goes well.
Frame will be prepped for paint this week Er5 is going to the unit and the 84 b1 is coming out of storage :)
  • 2 weeks later...
once they blu then the chrome is discoloured you might be able to polish it to reduce the bluing effect but you will not cure it
Ok was worth asking, i can get it shiny after a lot of polishing.
P.s i still have the er5 i might keep it until i pass, i had a proper ride on friends private road!! So its in storage ready to ride in the future
Must admit.
It does bring back a lot of memories. AR 125 was my first bike as a 17 year old. :thumb:
Love the new colour :thumb: looks like a fun little project.
Hiya, me too i will be renewing the colour later on same colour code and silver pin line,
I love the retro clashy colours
I love 2 strokes! personally I'd leave the blueing! adds character! :lol:
Hi rennie,
I have left it well an truelly a lone, as my build i only have an hour here and there every evening, but i agree it dose add character
Must admit.
Sure it isn't your old one ;)
It was brought from kawasaki dealer in 1997 its a ex show room bike 1984 b1 it was last road worthy in 1998 then i stumbled a cross it in 2011 in a corner of a breakers yard and paid £250 then 280£ on a spares engine.
I will revile the reg plate later on
I am 2nd owner on paper work, i am sure it has changed hands many times off paper work
Finally had an hour spare after work yesterday, removed the engine and fitted the donor engine as it looks like there is a good piston in it, good bright spark.
Here is a up date picture main goal is to get the mounts tighten'd and carb of to clean full service then ill try fire it up. I have put the stand exhaust on it for now
http://i1156.photobucket.com/albums/p562/classickid21/kawasaki%20ar125%2084%20b1%20build/7A17F1F0-EBB0-4F26-B939-E6795723167D_zpshhcv04qh.jpg
Sorry for the poor angled photos
http://i1156.photobucket.com/albums/p562/classickid21/kawasaki%20ar125%2084%20b1%20build/DA71AFAC-3A84-4ABF-9BDB-C81E3C397CF3_zpstaefxzny.jpg
I still have a long list of odds and ends to buy.
try vinegar on the blueing, I had a 1984 unrestricted one, 85mph(on the clock) flat out, it was cheaper than a restricted one
Thank you i will try this once i have time :)
HI Everyone had a few hours today to have a look at it,
finally got the mircon Exhaust fitted Happy days still a long list to do currently just got it complete almost to see what needs doing.. here are some update pictures
http://i1156.photobucket.com/albums/p562/classickid21/kawasaki%20ar125%2084%20b1%20build/EBDC39BD-470C-4750-97B8-6F13CB3BBFBE_zpskv9x4gln.jpg
http://i1156.photobucket.com/albums/p562/classickid21/kawasaki%20ar125%2084%20b1%20build/7F75D037-2B74-4C82-8738-8593DCE98989_zpsi4iejak6.jpg
list to do when i get time
parts to buy
rear brake switch
clutch cable
throttle cable
number plate
handle bars cover
igtion barrel
list of few bits that need doing
front brake master is slightly loose
brake need adjusting
pump air up in tyres
head light unit and brackets all move
indicators on the rear need fitting
speedo unit loose
fit the rad cover loose sitting for the photo
drain fuel tank
fit rubber out let
few parts need painting
fix rear panel
fit grab rail properly
reroot wirring around the head light
fit new parts
new fluids all round 2t had a tea bag in the TANK WTF ?
parts to buy
rear brake switch
clutch cable
throttle cable
number plate
handle bars cover
igtion barrel
speedo unit loose
drain fuel tank
fit rubber out let
fix rear panel
fit new parts
maybe someone shouted t2sugars so it could of been worse
parts to buy
rear brake switch fitted
clutch cable ----- not impressed ebay supplier sent the wrong item out
throttle cable fitted
number plate ordered on its way
handle bars cover i realised i had one just need to remove from top yoke
igtion barrel ---- supplier sent me a shockingly sh%t barrel most my keys turned it on... not impressed
indicators on the rear need fitting (fitted just need to drill some holes
fix rear panel ---- cable tied for now
fit grab rail properly ----- no point will be removed when its painted
UPDATE ...
ordered a long list of goodies
Started 2nd kick on easy start (rarely use that shit) but tank inside is fuel of rust :'( a lot of it cable out... its sluggy and fine like salt or fine bits of rust
lights work happy days
need to do .... next
fit a new front tire as the wall is cracked
disconnect 2 t pump
drill holes for number plate and indicators
build a bracket for the head light unit bar with two holes
pump tyres up
put fluids in
to re order a kawasaki or fowlers genuine Ar I/switch!!
respray the donor tank purple :) fun joys or some how clear the purple tank of slush and fine rust any tips ?????????
http://i1156.photobucket.com/albums/p562/classickid21/kawasaki%20ar125%2084%20b1%20build/D1F34C2F-F2B2-4C3C-84A7-3B9A1FA97659_zpsoi47al92.jpg
http://i1156.photobucket.com/albums/p562/classickid21/kawasaki%20ar125%2084%20b1%20build/145FD587-614B-4FA6-9F24-91AE5A783E50_zpskyxvjva5.jpg
