Cpt_Tact Posted April 23, 2016 Posted April 23, 2016 [list=] Well on the way back from a good ride, came to the last round about before home and the bike just died. Started it up and it sounded like a tractor and then died again on low revs. Nursed it back the mile to home and initially I thought one of the header pipes had come loose (hence the very loud noise) but when stopped I gave it a little revs and it has a very loud rattle around the top end which increases with the revs and then goes at idle. I am thinking valve/ timing issue as cam chains tend to rattle at idle and then goes on revs. Or could it be the big end Any quick checks I can do myself with a manual/ youtube before trailering it down to a garage? I'm not a mechanic but also not a monkey with a spanner. Thanks in advance! Quote
fullscreenaging Posted April 23, 2016 Posted April 23, 2016 CCT Cam Chain Tensioner Renowned on these bikes. I changed mine when I had my 2002 F2. Easy to to do yourself. Got the CCT from David Silver Spares. Sent from my iPhone using Tapatalk Quote
Stu Posted April 23, 2016 Posted April 23, 2016 as soon as I saw cbr600 f3 - very loud rattle I thought straight away CCThopefully the chains not skipped! Quote
Cpt_Tact Posted April 24, 2016 Author Posted April 24, 2016 Started her up this morning and was running fine! Will take her out for a gentle spin and see if it starts again when hot. I think you guys are right and that it is the CCT but freaked me out last night as it was bonkers loud Quote
Dynamo_Delboy Posted April 25, 2016 Posted April 25, 2016 Defo sounds like its the Can Chain Tensioner.Famous on the CBR600.I replaced mine with an APE manual CCT when i had my old CBR and never had a problem again with it. Quote
Cpt_Tact Posted April 26, 2016 Author Posted April 26, 2016 Turns out id blown a spark plug, CC is fine lol Quote
fullscreenaging Posted April 27, 2016 Posted April 27, 2016 [emoji15]Sent from my iPad using Tapatalk Quote
Fozzie Posted April 27, 2016 Posted April 27, 2016 9 times out of 10 it's the tensioner.But with the F3 and F2 I've heard some horror stories that report snapped valves and buggered plugs. I wonder if the ones put in there as stock had a problem with the batch as this isn't the first time I've heard of this problem.Either that or someone fitted knock off NGK plugs, which fail badly Quote
Cpt_Tact Posted April 27, 2016 Author Posted April 27, 2016 Replaced this time last year but looks like my own fault as partial to the kill switch backfire in busy towns Quote
Stu Posted April 27, 2016 Posted April 27, 2016 have you got a race can and open filter on too? Quote
Cpt_Tact Posted April 28, 2016 Author Posted April 28, 2016 Race can yes but no on filter, just standard OEM. Quote
Stu Posted April 28, 2016 Posted April 28, 2016 was just thinking you might want to stick it on a dyno to make sure its fuelling ok If its running lean that could be the cause of the blown plug and you maybe doing more damage! be worth it for peace of mind if nothing else Quote
