Stu Posted June 14, 2016 Posted June 14, 2016 There is no such thing as a car or bike tyre machine You just need some rim protectors as the clamps are metal Quote
Stu Posted June 15, 2016 Posted June 15, 2016 Here is my top tip Fro buy one of these tyre changers and a bar for alloy wheels!! mine turned up today and the hardest part was bolting it down I wish I had bought one of these years ago! baring in mind I only got it today so first use it took me less than 20 mins to change the front and that was just plodding on not rushing at all there was next to no effort although it is a bit tricky holding the tyre in the centre of the rim and one side pulling the bar and making sure the tyre is going on! you need 3 arms Quote
Mr Fro Posted June 15, 2016 Author Posted June 15, 2016 Sounds good Stu. How much did the whole lot set you back? Quote
Stu Posted June 15, 2016 Posted June 15, 2016 about £230 that bar laid across the top is an extra bar I bought I will get the links if you want Quote
Stu Posted June 15, 2016 Posted June 15, 2016 I got the tyre changer from here http://www.buycarspares.co.uk/tc965-motorcycle-mini-tyre-changer" onclick="window.open(this.href);return false; cheapest I could find it and free delivery And this is the bar I got http://www.ebay.co.uk/itm/172236566054" onclick="window.open(this.href);return false;make sure you are in when they get delivered as they aren't light!! Quote
Mr Fro Posted June 15, 2016 Author Posted June 15, 2016 Looks like it needs a bit of space - might have to wait until the garage gets extended.What are you doing about balancing? Quote
Stu Posted June 15, 2016 Posted June 15, 2016 you don't need a great deal of space but it needs to be away from the walls I have bolted it down but can removed them if need be to move it out the way! although I have a fair bit of space I have a static balancer too this was about £30 Quote
