Paul-Kent Posted July 25, 2016 Share Posted July 25, 2016 Here's an odd oneThe tenere cut out 3 times on my way home the day I bought it, I put it down to the amount of water that was around at the time. The bike didn't actually stop but cuts out for a second or two then carries on as normal. It happened 3 times in about 5 mins Yesterday in my way home same thing happens, oddly on the same stretch on the m25!Fuel tank still had 8 litres so I'm ruling low fuel outAnybody got any ideas?The dealer has told me to run it into my local shop for them to diagnose/ fix at their cost but it is gonna be hard to pinpoint as its so intermittent Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
RantMachine Posted July 25, 2016 Share Posted July 25, 2016 Is it happening at specific RPMs? Quote Link to comment Share on other sites More sharing options...
Paul-Kent Posted July 25, 2016 Author Share Posted July 25, 2016 Both times when in outer lane doing 70-75But was fine earlier when going up m11 on the way out Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
Stu Posted July 25, 2016 Share Posted July 25, 2016 Avoid the m25! Has it got an immobiliser? Does it do it on a certain stretch? Could be interference from a nearby mast If not then its more than likely an electrical issue somewhere! Quote Link to comment Share on other sites More sharing options...
Paul-Kent Posted July 25, 2016 Author Share Posted July 25, 2016 It's m25 south east section between Essex and Kent but not down to a few meters Very oddSent from my iPad using Tapatalk Quote Link to comment Share on other sites More sharing options...
Guest Posted July 25, 2016 Share Posted July 25, 2016 Sounds fuel pumpish/pressure Quote Link to comment Share on other sites More sharing options...
Classickid21 Posted July 25, 2016 Share Posted July 25, 2016 Coil breaking down maybe ? Is it like a misfire ? Tried different plugs ? Quote Link to comment Share on other sites More sharing options...
Paul-Kent Posted July 26, 2016 Author Share Posted July 26, 2016 But why would it only happen in a short period and then just carry on as normal.Both episodes happen toward the end of a long ride, I wonder if that has any bearing on it?Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
