hardleydavidson Posted September 19, 2016 Posted September 19, 2016 Hi,I've recently purchased a new front brake/master cylinder and the chamber is considerably larger than the old one, would this cause an issue? I need to change the brake fluid when I fit it but will the larger chamber insert more force? Quote
Stu Posted September 19, 2016 Posted September 19, 2016 You get more fluid flow so less lever movement before the brakes are on! Quote
hardleydavidson Posted September 19, 2016 Author Posted September 19, 2016 Thanks, shouldn't be a problem though? Quote
eastanglianbiker Posted September 19, 2016 Posted September 19, 2016 no it wont be a problem if anything it will just make the front brake sharper so take it easy at first Quote
Mr Fro Posted September 19, 2016 Posted September 19, 2016 Do you mean the bit you pour the fluid in to? If so then it makes no odds.If it's the cylinder itself then you'll move the lever less to engage the brakes but it'll require more force to provide the same braking effort. Quote
hardleydavidson Posted September 19, 2016 Author Posted September 19, 2016 Glad I found out cheers! Quote
