hardleydavidson Posted October 22, 2016 Posted October 22, 2016 Hi,So, after getting the engine going I find the clutch is stuck. I can pull the lever and there is tension, but when I put it in 1st and pull the clutch the gear is still engaged. I have a straight gearbox, neutral, down for 1st, down for 2nd etc.Any tips to free this without having to take the case off would be appreciated. Quote
eastanglianbiker Posted October 22, 2016 Posted October 22, 2016 if it hasnt been parked up for long its unusual for the clutch to stick up have you trried leaving the engine off put the bike into gear pull clutch lever in and rock the bike to see if it frees off or even let the bike warm up so the oil is warming up and then see what happens Quote
hardleydavidson Posted October 22, 2016 Author Posted October 22, 2016 I'll give that a go, it's been sat sitting for a good 6 months, turned the engine over now and then but never thought about the clutch Quote
TimR Posted October 22, 2016 Posted October 22, 2016 Is this with the bikes rear wheel off the ground that it's spinning ? It's not just the clutch idling as no load on wheel that make you think it's still engaged Have you tried wheel on ground and clutch pulled in ? Quote
hardleydavidson Posted October 23, 2016 Author Posted October 23, 2016 Both wheels o the ground, tried rocking it back and forth in all gears, tred bumpstarting it without the ignition on and then pulling the clutch but no joy. Quote
fq-craigus Posted October 23, 2016 Posted October 23, 2016 My dad's bike is really bad for this but it sits for long periods. A oil and filter change helped but sometimes he still needs to either rock the bike to release or run up to temp and the plates release. New clutch plates would be the proper solution they are maybe past their best Sent from my SM-G930F using Tapatalk Quote
Stu Posted October 23, 2016 Posted October 23, 2016 Some FJR's have had a problem like this the solution on those is to pull the clutch and soak it in oil Because the clutch is high up on the FJR the oil drains off and the inner plates don't get enough oil Quote
hardleydavidson Posted October 24, 2016 Author Posted October 24, 2016 Tried the rubber mallet, tried bouncing it, rocking it, swearing at it.Read that this might work though...Run the engine so it heats up to operating tempPosition bike so front wheel is against a wall and sit on itPull the clutchWhack it in 1stThe theory being that with the rear wheel being unable to rotate it will free the clutch, I don't know anything about clutches so I don't know if this would work. Quote
JRH Posted October 24, 2016 Posted October 24, 2016 If you are going to try the engine running method you need to have the rear brake on. Just holding against a wall will either stall the engine or allow the rear to spin.if you have a centre stand you could start the engine and in gear repeatedly stamp on the brake to try and release the clutch.not tried this on any bikes so i accept NO responcibily if it goes t**s up. Have had to do this in the past with cars though. but they did not have a centre stand. Quote
Guest Posted October 24, 2016 Posted October 24, 2016 Last one i rode around with the clutch pulled in and waited until it gave way Quote
