Hello,
I am looking for some advise regarding an installation for a remote completely off grid garage installation. This needs to power a couple of 12v LED strip lights for intermittant use. Along with a 12v external light which will be triggered by a PIR.
I will also be running a point to point wireless network point to the garage unit, so this will need to be able to power this 24h a day. The power usage is about 30w for this. This will be powered via a cheap inverter as the load is very low.
I plan on having a battery minder attached to the setup for continual charging of my motorcycle batteries. I will eventually add a larger inverter to power some additional tools in the garage also.
For now I am looking for a cheap (but functional) setup. This is what i've got so far;
Sun YOBA LCD Display 60A 12V (Charge Controller) https://www.amazon.co.uk/dp/B00ADKOMXI/ref=wl_it_dp_o_pC_nS_ttl?_encoding=UTF8&colid=1ZNNW63YABJSD&coliid=I147S0TDQ3AVLG
135AH 12v leisure battery https://www.amazon.co.uk/gp/product/B00WQ0J92W/ref=ox_sc_act_title_5?ie=UTF8&psc=1&smid=A1MI474ZFJ1AC
200watt monocrystaline panel (will add further later) https://www.amazon.co.uk/Photonic-Universe-monocrystalline-batteries-motorhome/dp/B00BE6ARPM/ref=sr_1_1?ie=UTF8&qid=1480885605&sr=8-1&keywords=200watt+solar+panel
BESTEK 300W Power Inverter DC 12V https://www.amazon.co.uk/BESTEK-Inverter-Converter-Outlet-Charger/dp/B00INW611Y/ref=sr_1_3?ie=UTF8&qid=1480885655&sr=8-3&keywords=12v+inverter
This comes to approx £300 (excluding associated cabling / crimps and so on).
I am looking for a bit of input into how this setup looks. I am a complete novice with regards to Solar.
Why do you need 24hour wireless?
Anywhere you have an inverter you have energy loss.
Instead of converting 12v DC to 240vAc then plugging in a transformer for the WiFi that drips the voltage back down to 12vDC, look to see if you can run he wireless direct from the batteries.
Good point Joeman. The router could be run straight from the dump on the charge controller I suppose as the battery will fill up pretty quickly with a 200W panel.
I run 8W worth of panels to an old 065 battery (plus a couple of 7ah PSU batteries) to drive 9x LED MR16 bulbs. That's plenty bright enough and I rarely run out of juice.
Sounds like a fun project though - let us know how it goes!
I have done some further reading on this, I can run the WiFi bridge directly from the battery at 12v. This will need testing but will simplify things hugely at the outset.
Chrissb6, I am going to be running a leisure battery, A deep cycle marine unit.
