Guest Posted March 2, 2008 Share Posted March 2, 2008 Ive got an NSR 125 92 alcast model which has been an on off project for more than a year now. The problem is when I turn the ignition on theres no lights, no indicators and wont turn over the only thing that works is the horn but its really quiet. Ive tried changing the regulator rectifier but it didnt change anything, any ideas? Quote Link to comment Share on other sites More sharing options...
Voodoo Posted March 2, 2008 Share Posted March 2, 2008 Is the battery charged? Quote Link to comment Share on other sites More sharing options...
Guest Posted March 2, 2008 Share Posted March 2, 2008 Investing in an optimate is a gud idea if it's not having regular runs out. I used to have electrical problems with my TZR all the time until we got one of these. Never had a problem afterwards.X Will X Quote Link to comment Share on other sites More sharing options...
Guest Posted March 2, 2008 Share Posted March 2, 2008 Battery is brand new, have also checked its charged on my charger Quote Link to comment Share on other sites More sharing options...
Guest Posted March 2, 2008 Share Posted March 2, 2008 Battery is brand new, have also checked its charged on my charger Guess it's a process of illimination then hun...fusses, checking all the connections.etc.... Quote Link to comment Share on other sites More sharing options...
techno Posted March 2, 2008 Share Posted March 2, 2008 Ideas yep..get it to a bike garage! Quote Link to comment Share on other sites More sharing options...
Voodoo Posted March 2, 2008 Share Posted March 2, 2008 As Willow said, check main fuse next Quote Link to comment Share on other sites More sharing options...
Guest Posted March 2, 2008 Share Posted March 2, 2008 Fuse is good all the connections seem fine as well Quote Link to comment Share on other sites More sharing options...
yorbandit Posted March 2, 2008 Share Posted March 2, 2008 Well now ya need a volt meter mate and find where ya got power and where ya have not Quote Link to comment Share on other sites More sharing options...
Voodoo Posted March 3, 2008 Share Posted March 3, 2008 Next thing I'd try then is turn on the ignition, turn your lights on and start wiggling all the wires especially where they exit your ignition barrel, hopefully you'll get lucky and find a dodgy wire. If that doesn't work then my next step would be an auto-electrician. Quote Link to comment Share on other sites More sharing options...
Guest Posted March 3, 2008 Share Posted March 3, 2008 They were made in Italy .....Speaks volumes dunt' it You'll suss it though ..................... Quote Link to comment Share on other sites More sharing options...
Guest Posted March 3, 2008 Share Posted March 3, 2008 It sounds to me like you have a poor earth connection.Follow the big black wire from the battery and it goes to the engine casing.It also splits to earth the frame etc.Check all connections are good. If it is a project you will probably find dirt under one of the connections.Dont just wiggle it, remove, clean and reassemble.Good luck. Quote Link to comment Share on other sites More sharing options...
