Hi, Have just tried to start my 125 vl after the winter storage,fired up went onto 1 cylinder and will now will only run if I spray fuel into air cleaner port,fuel at the pump inlet,any ideas will be welcome
Cheers
Mick
Welcome to TMBF mate. .....pop over to the Newbies section and introduce yourself to the guys when you can. ...... 8-)
Is the bike carbed or injection? .....have you checked for a spark at the plugs? My guess is fuel starvation..... :wink:
Hi ,it,s a 2000 model with a carb,i think it has a pump which works by a vacuum system,it will run all the time if I spray easy start into air cleaner box,got a manual on cd but can,t find the bleeden thing
cheers
Mick
Give the carbs a tap with the blunt end of a screwdriver on the float bowls, in case the floats have stuck..... 8-)
  • 2 weeks later...
Hi, Tapped the carb,blew through the pipes that go to the pump/carb,sprayed petrol into the air intake and it started to run ok,so not sure why it started, but thanks for the reply
Mick
Sounds like something had stuck and now it's freed up......hopefully it'll keep running now...... 8-)
