mattyarmstrong Posted April 21, 2017 Posted April 21, 2017 https://www.youtube.com/watch?v=hgTSGsTsBJIHi Guys! I've had this bike just less than a year now and I was out riding when all of a sudden it started doing this! I can't get any higher than 15mph and I can't work out if it is something I may have knocked or if it's not as simple as that!? Any help would be gratefully received! Matt Quote
Northern Biker Posted April 21, 2017 Posted April 21, 2017 Does rev freely when you just sit and rev it or does it only do it under load when riding?Done any work to it recently?Could be a fuelling issue as it sounds like what mine does if I forget to turn the choke off, it bogs down. Quote
mattyarmstrong Posted April 22, 2017 Author Posted April 22, 2017 It only does it under load! It revs perfectly smooth when stationary. I haven't done any work on it at all, is there an easy fix for the fuelling issue? Thanks! Quote
Tango Posted April 22, 2017 Posted April 22, 2017 I'd start off with replacing the plug and making sure everything is good around the battery....terminals are tight. Also make sure that there's no air leaks around the carb.....particularly where it joins the cylinder head......check the condition of your air filter and make sure there's nothing blocking the air inlet into the airbox...... Quote
