Having an issue with my sr50, when i switch it off the indicator lights just keep flashing, to stop this i have to remove the 15A fuse then put this back in to start my ped again. Any one have any clues to what it could be?
The flasher relay is 'sticking'. Replace it (they are not expensive).
:cheers:
Sorry - Re-read your post../.. It only happens when you turn the ignition off? If so, then the voltage feed to the flasher relay from the alarm is not 'disappearing' and this will be due to a bad contact within the ignition circuit (ECU / Relay - You will need to check with a multi-meter and have access to a wiring diagram).
:thumb:
I have thoroughly checked all of this, still to no avail.
When the ignition key is turned to the 'OFF' position, there is still electric running to the bike as the clocks do not go off and I have the indicator issue still.
So frustrating, I just do not know where else to look.
Any more suggestions would be fantastic! :)
