Liveware Problem Posted February 15, 2018 Posted February 15, 2018 Hi!I'm trying to fit a fork stem attachment to my bike (triumph TT600) for the purpose of holding a Sat nav,I removed the steering head nut (if that's what it's called?) and fitted the mount: However I realise the nut needs to be replaced with one without a cap on, wondering what would be suitable - something like this?https://m.ebay.co.uk/itm/HIGH-TENSILE-SELF-COLOUR-BLACK-METRIC-HEXAGONAL-HEX-STEEL-FULL-NUTS-CLASS-10/122261968385?hash=item1c77619601:m:mh6tFrMJP4jhQlgYLOMvfZQOr if not then what would be appropriate?Thanks in advance Quote
oldgrump Posted February 15, 2018 Posted February 15, 2018 Hi, the nut will be a fine thread, so probably not from that store, you could if you knew someone with lathe just machine chrome cap off, or look online at pro-bolt, think they do top nuts. Quote
Chrissb6 Posted February 15, 2018 Posted February 15, 2018 something like these maybe?https://www.bearingboys.co.uk/Lock-Nuts-1084-c Quote
Liveware Problem Posted February 15, 2018 Author Posted February 15, 2018 something like these maybe?https://www.bearingboys.co.uk/Lock-Nuts-1084-c Thanks! Would I need a special tool to attach one of those though? Quote
Chrissb6 Posted February 15, 2018 Posted February 15, 2018 (edited) something like these maybe?https://www.bearingboys.co.uk/Lock-Nuts-1084-c Thanks! Would I need a special tool to attach one of those though? May be but as already mentioned make sure you know the thread pitch before you buy This one i've just found should tick the boxhttps://www.ebay.co.uk/itm/Aluminium-Honda-CBR-VFR-CBF-Other-Top-Yoke-Nut-M24-x-1-00mm-Silver/322111757617?hash=item4aff5b5d31:g:ydQAAOSw9VZXOwZvSorry l was thinking, Honda but check the thread anyway Edited February 15, 2018 by Chrissb6 Quote
Liveware Problem Posted February 15, 2018 Author Posted February 15, 2018 something like these maybe?https://www.bearingboys.co.uk/Lock-Nuts-1084-c Thanks! Would I need a special tool to attach one of those though? May be but as already mentioned make sure you know the thread pitch before you buy This one i've just found should tick the boxhttps://www.ebay.co.uk/itm/Aluminium-Honda-CBR-VFR-CBF-Other-Top-Yoke-Nut-M24-x-1-00mm-Silver/322111757617?hash=item4aff5b5d31:g:ydQAAOSw9VZXOwZv Cheers However I don't know the thread pitch or how to find out what it is! Quote
fastbob Posted February 15, 2018 Posted February 15, 2018 something like these maybe?https://www.bearingboys.co.uk/Lock-Nuts-1084-c Thanks! Would I need a special tool to attach one of those though? You could finger tighten it and then gently tap it round with a hardwood drift to avoid damage or use a small C spanner. If it we're me I'd go for the previous suggestion to machine the cap off the old one. Quote
Liveware Problem Posted February 15, 2018 Author Posted February 15, 2018 something like these maybe?https://www.bearingboys.co.uk/Lock-Nuts-1084-c Thanks! Would I need a special tool to attach one of those though? You could finger tighten it and then gently tap it round with a hardwood drift to avoid damage or use a small C spanner. If it we're me I'd go for the previous suggestion to machine the cap off the old one. Thanks, I don't know anyone with a lathe so I think I'll need to buy one.Measures the diameter, I think I'll need an M22. Quote
oldgrump Posted February 15, 2018 Posted February 15, 2018 Hi, just looked at triumph parts list but no thread size on there, to find the pitch size of thread you need a in-expensive little tool, local hardware shop might stock it or they come in a Tap & Die kit. And you just line it up with thread so gauge fits thread you are measuring and read what's marked on side. Normally about a 1m/m thread, but don't take my word for it. here's a couple pictures of gauge.. Quote
Chrissb6 Posted February 15, 2018 Posted February 15, 2018 Thanks! Would I need a special tool to attach one of those though? You could finger tighten it and then gently tap it round with a hardwood drift to avoid damage or use a small C spanner. If it we're me I'd go for the previous suggestion to machine the cap off the old one. Thanks, I don't know anyone with a lathe so I think I'll need to buy one.Measures the diameter, I think I'll need an M22.That ebay item l loaded is Thread M24 x 1.00mmMaterial - High Tensile Anodised Aluminium Quote
Liveware Problem Posted February 15, 2018 Author Posted February 15, 2018 You could finger tighten it and then gently tap it round with a hardwood drift to avoid damage or use a small C spanner. If it we're me I'd go for the previous suggestion to machine the cap off the old one. Thanks, I don't know anyone with a lathe so I think I'll need to buy one.Measures the diameter, I think I'll need an M22.That ebay item l loaded is Thread M24 x 1.00mmMaterial - High Tensile Anodised Aluminium Got one on the way.. if it doesn't fit I'll have to get one of those tools [mention]oldgrump[/mention] mentioned Quote
Chrissb6 Posted February 15, 2018 Posted February 15, 2018 Thanks, I don't know anyone with a lathe so I think I'll need to buy one.Measures the diameter, I think I'll need an M22.That ebay item l loaded is Thread M24 x 1.00mmMaterial - High Tensile Anodised Aluminium Got one on the way.. if it doesn't fit I'll have to get one of those tools @oldgrump mentioned Hope it all works out mate. Defo need a locking nut for the headstocks Quote
Liveware Problem Posted February 17, 2018 Author Posted February 17, 2018 Jobs a good 'un I even used a torque wrench to tighten it (instructions with the nut said as per the triumph specs -30%)!Cheers guys Quote
