Philmorgs Posted April 15, 2018 Posted April 15, 2018 2007 sv650, noticed some smoke coming out of rubber pipe attached to far left senser box on the air box, I then heard a pop and the check oil light and FI come on. Turned off engine started again and the same lights came on. Oil level fine, so checked pipe which had burst and then snapped explains the pop I guess. Currently struggling to find a relplacement pipe as I do not no the name of it. Any ideas? Hopefully a easy fix Quote
Tango Posted April 15, 2018 Posted April 15, 2018 From CMSNL......part 22 on the diagram? https://www.cmsnl.com/suzuki-sv650-2003-k3-usa-e03_model16252/partslist/BLCK0003.html#results Quote
fastbob Posted April 15, 2018 Posted April 15, 2018 Halfords do bleed air pipe , might fit , probably cheaper . Quote
